Optimizing Foreground Performance of the Repository Merge
To improve the foreground performance of the repository merge, use the following procedure.
To increase the foreground performance of the repository merge
From the Start menu, choose Control Panel, and then the System menu option.
Select the Advanced tab.
Select the Performance Options button.
In the Application Response box, click the Applications radio button and click OK.
While the repository merge process is running, click on the title bar of the Siebel Tools application to verify that the Siebel Tools application is the foreground application on the computer.
Note: After the repository merge process has finished, set the
Performance setting back to its former value.
