Using Shortcut Keys to Run a Query
You can use a shortcut key to run a query.
To use shortcut keys to run a query
- In the Object Explorer, click the object type that you want to locate.
- In the Object List Editor, enter - ALT+Qin Web Tools.
- In the Object List Editor, enter the query. - For more information, see Simple Query Operators and Compound Query Operators.
- Press the ENTER key. - The query results are returned.
