Translating iHelp Items
When translating an iHelp Item, only the text strings that the user sees are translated. These text strings are:
- Item name
- Section labels
- Step captions
- Substep captions
If translation is not defined for a language, then the text from the base record appears.
This task is a step in Process of Administering iHelp.
To translate an iHelp item
- Navigate to the Administration - iHelp screen, then the Translations view.
- In the iHelp Items list, select an iHelp item.
- In the Translations list, create a new record, and complete the necessary fields. - Some fields are described in the following table. - Field - Comments - Display Name - Type the display name for the translation of the iHelp item name
- Navigate to the Designer view.
- For each step, complete the following steps: - Open the Translations folder.
- Create a record to the Translations list and complete the necessary fields.
- For each substep, complete the following steps: - Open the Translations folder for the substep.
