Associating a Feature with a Product
Use this procedure to associate a feature with a product.
This task is a step in Adding Product Features and Specifications.
To associate a feature with a product
- Navigate to the Administration - Product screen, then the Products view.
- Drill down on the Name field link for a selected product record.
- In the Administration - Product link bar, click the Features link.
- In the Features list, create a new record.
- In the Category field, select the category for the feature you just created in Working with Product Features.
- Complete the fields as necessary.
