Working with Product Specifications
Use this procedure to view, edit, create, and delete a specification for a product.
This task is a step in Adding Product Features and Specifications.
To view, edit, create, and delete a specification for a product
- Navigate to the Administration - Product screen, then the Specifications view.
- In the Specifications list, add, edit, or delete records.
