Associating Suite Specific Spaces with a Category
After creating the suite category, you can assign suite specific spaces to the category.
This task is a step in Process of Setting Up Suites.
To associate suite-specific spaces with a category
Navigate to the Property Administration screen, then the Properties view.
In the Properties list, query for the required property record.
Click the link in the Property Name field, and then click the Category view tab.
In the Category list, select the suites category, and then scroll down to the Specific Space view tab.
In the Specific Space list, create a new record and select a suite-specific space.
