Setting Up a Suite Category
You can set up a category to group indivisible or configured specific space suites.
This task is a step in Process of Setting Up Suites.
To set up a suite category
Navigate to the Property Administration screen, then the Properties view.
In the Properties list, query for the required property.
Click the link in the Property Name field, and then click the Category view tab.
In the Category list, create a new category, and set the value in the Type field to Suite.
Complete the other fields, as required.
For more information about the fields on the Property Administration screen, Category view, see Setting Up Function Space Categories for a Property.
