Named Method 16
Use this user property to refresh the business component when the SetParentSplitFlag method is called.
Property | Description/Value |
Value |
"SetParentSplitFlag", "INVOKE", "TNT SHM Quote Item", "RefreshBusComp" |
Parent Object Type |
TNT SHM Quote Item business component |
Usage |
Calls an internal service method to set the appropriate value for the Split Menu Flag of the parent menu, when the TNT Split Qty Flag field of an associated child menu item is updated. This user property works with the On Field Update Invoke user property. |
