Named Method 17
Use this user property to update the Quantity if Guaranteed/Projected/Expected Num changes in the Parent BC TNT SHM Function.
Property Description/Value
Value
"UpdateField", "SET", "Quantity Requested", [QuantityCalc]
Parent Object Type
TNT SHM Order Item business component
Usage
Updates the Quantity of TNT SHM Order Item if Guaranteed/Projected/Expected Num changes in the parent business component TNT SHM Function.
