Configuring Batch Engine Parameters for Statements for Use with LDAP Authentication
You can use batch engine parameters with the object type of Statement to control the processing of Loyalty statements.
However, if you use LDAP for authentication, then you must configure the application by updating the following user properties in the LOY Statement business service:
  • LDAPUserId. Update with the username.
  • LDAPPassword. Update with the password.
If you have not enabled LDAP, then this configuration is not necessary. You can use batch engine parameters with the object type of Statement without this configuration. For more information about LDAP authentication, see Siebel Security Guide.
