Adding a Single Product as a Component
You can create a relationship that adds a single product as a component of a product with components.
This task is a step in Process of Designing a Product with Components.
To add a single-product relationship
Navigate to the Administration - Product screen, then the Product Definitions view.
In the Products list, select and lock the desired product with components.
In the Versions list, click the Work Space version.
In the Structure list, add a new record and complete the necessary fields, described in the following table.
Field Comments Relationship Name
Enter a name for this relationship.
Product
Select the product that is a component of this product with components.
Minimum Cardinality, Maximum Cardinality, and Default Cardinality
Enter the minimum, maximum, and default cardinality for the product. For more information, see About Cardinality.
