Process of Designing a Product with Components
To define a product with components, perform the following tasks:
Creating Product Records for a Product with Components and for Its Components
Add components to products with components, which can be done in the following ways:
Adding Products as Components Using the Dynamic Class Domain
Adding a Group of Products from Different Classes as Components
Note: Instead of defining the structure of an individual product with components, as described in this process, you can define the structure of a product class. Products associated with the class inherit both the structure and constraints from the class. For more information, see About Product Classes.
