Adding the Validation Services Record
The Validation Services record contains the name of the validation business service to call.
This task is a step in Setting Up Product Validation Using the Simple Expression Business Service.
To add the Validation Services record
Navigate to the Administration - Product screen, then the Products view.
Click the Product Validation view tab.
In the link bar of Product Validation view, click Validation Services.
Add one or more new records to the Validation Services list and complete the necessary fields, as described in the following table.
Field | Comments |
Sequence |
Enter a number that controls the order in which the validation services are executed. You can create an unlimited number of validation services. |
Business Service |
Select the business service used to execute this rule. In this case, select VORD CPVE Simple Validation, the provided product validation business service that ships with the product. |
Rule Type |
Select a rule type. The options are as follows:
In this case, you must select Complex or All for use with the VORD CPVE Simple Validation business service. |
