Creating the Messages for Product Validation
You must use the Administration - Application screen, then the Message Types view to define the error messages that the product validation rule will display.
For more information about defining messages, see Siebel Order Management Infrastructure Guide.
To create the messages for product validation
Navigate to the Administration - Order Management screen, then the Message Types view.
In the All Message Types list, add a new record for each message and complete the necessary fields, as described in the following table.
Field | Comments |
Name |
Enter a name for the message record. When you add rules in the Simple Validation Expression Rules list, this name will be used to link the rule to a message. |
Group |
If you are using the validation service VORD CPVE Simple Validation, which ships with the product, as the group, you must enter Simple Expression Rule. |
Full Text |
Enter the error message that is displayed by the application. Note: Only the Full Text field is used by
the product validation engine. The Short Text field is ignored. |
