Configuring Security Adapter Parameters for Developer Web Clients
For Developer Web Clients, security adapter parameters are configured in the configuration file of the application for which you are implementing LDAP security adapter authentication rather than in the gateway.
Parameters in sections of the application configuration file that directly pertain to security adapters apply, in this context, only to the Siebel Developer Web Client. These parameters are counterparts to the parameters (for Siebel Gateway) listed in the tables in the following topics:
To configure a security adapter for the Developer Web Client, provide parameter values, as indicated by the guidelines in the following table, in the configuration for the Siebel application for which you are implementing LDAP security adapter authentication.
You can use a text editor to make changes to an application’s configuration, or you can do so using the Siebel Management Console. For more information about editing an application’s configuration and about the purposes for the parameters, see Siebel Application Configuration Parameters. For a list of Siebel application configuration files, see Siebel System Administration Guide.
Section |
Parameter |
[InfraUIFramework] |
AllowAnonUsers For the AllowAnonUsers parameter, enter Set this parameter to Note that AllowAnonUsers is a server parameter, and it is not available in the Siebel Management Console. |
[InfraSecMgr] |
SecAdptMode For the SecAdptMode parameter, specify For more information about setting this parameter, see the Enterprise Security Authentication Profile (Security Adapter Mode) parameter in the table in Parameters for Configuring Security Adapter Authentication. |
[InfraSecMgr] |
SecAdptName For the SecAdptName parameter, specify For more information about setting this parameter, see the Security Adapter Name (named subsystem) parameter in the table in Parameters for Configuring Security Adapter Authentication. |
[LDAPSecAdpt] |
For parameters, see Configuring Security Adapter Parameters for Siebel Gateway or Authentication Related Configuration Parameters. |
