Using the Push Keep Alive Driver for Session Connections
The Push Keep Alive communications driver provides a heartbeat message that is useful in maintaining connections for your communications sessions in some environments. You use this driver with Communications Session Manager, such as when you are using Siebel CTI.
The Push Keep Alive driver helps to solve problems that might be experienced in some environments, where push communications sessions between the Application Object Manager and a user’s Web browser are sometimes dropped. A connection might be dropped if messages have not been pushed to an agent for a particular length of time.
The Push Keep Alive driver sends a heartbeat message to the Application Object Manager and to each agent user’s browser, at a regular interval. This heartbeat message allows the push connection applicable to each agent’s communications toolbar not to be dropped in such cases. The heartbeat interval is specified using a driver parameter.
