How a Translatable String is Determined
To compile an object property that displays a translatable string, such as the Title property of an applet, the following happens:
If a value exists in the string language that the compile uses, then it compiles this string override value.
If the string override field for the current language mode that is set does not include a string value, then the current language mode and the String Value property of the associated symbolic string locale are used to determine the value.
In most situations, a string override does not exist. For more information, see Entering a String Override.
