Revising an Active iHelp Item
Complete the following procedure to revise an active iHelp item.
To revise an active iHelp item
  1. Navigate to the Administration - iHelp screen, then the All iHelp Items view.
  2. Select an active iHelp item.
  3. Click Revise.
Tip: Reset the responsibilities for the in-progress iHelp item so that you can see and test the item that you are revising.
