Process of Running Dynamic Assignment
This topic is part of Running Dynamic Assignment.
You run dynamic assignment only in default mode, which means that all active rules are loaded and processed. Rule group mode is not supported.
To set up dynamic assignment, perform the following tasks:
  1. (Optional) Reviewing Triggers for Dynamic Assignment
  2. Generating triggers, using either of the following procedures:
  3. Starting Workflow Monitor Agent for Dynamic Assignment Using the Server Manager Command-Line Interface
