Starting Workflow Monitor Agent for Dynamic Assignment Using the Server Manager Command-Line Interface
To run dynamic assignment, the Workflow Monitor Agent server component (WorkMon) needs to be running. This server component monitors the S_ESCL_REQ table. Database triggers, when fired because of object changes, create records in the S_ESCL_REQ table. The Workflow Monitor Agent reads these new records and processes requests for Assignment Manager policies. Affected objects are then dynamically assigned.
Note: Dynamic assignment does not log information into the S_ESCL_LOG table. For more information about log files, see Siebel System Monitoring and Diagnostics Guide.
Complete the steps in the following procedure to start workflow monitor agent from the Server Manager command-line interface (srvrmgr). This task is a step in the Process of Running Dynamic Assignment.
To start Workflow Monitor Agent from the Server Manager command-line interface
  1. Determine the workflow group that you want Workflow Monitor Agent to monitor.
    1. Navigate to the Administration - Assignment screen, and then the Assignment Policies view.
    2. In the Policy Group field in the Assignment Policies list, choose the workflow group (the default group is Assignment Group).
  2. Start the srvrmgr program.
    For detailed information on this task, see Siebel System Administration Guide. After the program starts, the prompt changes to:
    srvrmgr: server_name>
  3. At the prompt, enter the following information to start the Workflow Monitor Agent server component task; use the Group information gathered from the previous step (Assignment Group used in this example):
    start task for component workmon with GroupName="Assignment Group"
  4. Configure other component parameters, if needed.
    For more information about other configurable parameters, see the following table.
    Note: Separate the parameters and their values in the command-line statement with commas.
  5. Alternatively, you can configure a Workflow Monitor Agent to start automatically to process assignment requests whenever the Siebel Server starts.
    For more information about Workflow Monitor Agent, see Siebel Business Process Framework: Workflow Guide.
This command starts a new task running in the background and returns to the Server Manager immediately.
Note: It is possible to set up multiple Workflow Monitor Agents for dynamic assignment. For more information about setting up multiple Workflow Monitor Agents, see the information about starting Workflow Agent processes automatically with Siebel Server, in Siebel Business Process Framework: Workflow Guide.
The following table shows the Workflow Monitor Agent parameters.
Note: The Action Interval parameter has no effect on assignment policies, where Workflow Monitor Agent was started in the Administration - Assignment screen, and the Assignment Policies view, with the group Assignment Group. This parameter applies only to workflow policies created in the Administration - Business Process screen, and the Workflow Policies view. If you require this parameter, then invoke Assignment Manager through the Synchronous Assignment Manager Requests business service from within a workflow process. For more information, see How Siebel Assignment Manager Uses Server Key Mappings to Load Rules to a Particular Siebel Server. See also Siebel Business Process Framework: Workflow Guide.
Parameter Name
Alias
Description
Default Value
Action Interval
ActionInterval
Do not reexecute actions within specified interval in minutes.
Note: This parameter applies only to workflow policies, not to assignment policies.
3600
Cache size of Policy violations
CheckLogCacheSz
Number of policy violations to store in cache
100
Cache size of last user information
LastUsrCacheSz
Number of last user information items to cache
100
Group Name
GroupName
Group Name
Not applicable
Ignore errors
IgnoreError
Ignore errors while processing requests
FALSE
Mail Server
MailServer
Name of email server to send notification of abnormal termination
Not applicable
Mailing Address
MailTo
Email address to review notification of abnormal termination
Not applicable
Number of days to keep violation information
KeepLogDays
Number of days worth of violation information that should be retained
30
Number of seconds to retry
GenReqRetry
Number of seconds to retry sending a Generic Request message
120
Processes the batch Policies
BatchMode
Process the batch policies
FALSE
Reload Policy
ReloadPolicy
Reload Policy Interval, in seconds
600
Request delete size
DeleteSize
Request delete size
500
Requests per iteration
Requests
5000
Sleep Time
SleepTime
Time to sleep between iterations (in seconds), that is, is the frequency of time the Workflow Monitor Agent polls the S_ESCL_REQ table (escalation request table) and assigns rows.
For example, if SleepTime is set to 60 seconds, then the Workflow Monitor Agent polls the S_ESCL_REQ table, then waits 60 seconds before it polls it again.
60
Use Action Agent
ActionAgent
Use Action Agent
FALSE
For more information about starting, stopping, and monitoring server tasks, see Siebel System Administration Guide. For more information about the Workflow Monitor Agent, see Siebel Business Process Framework: Workflow Guide.
