Running Interactive Assignment Without Using Server Key Mappings
Assignment Manager supports the use of rule group mode even if you do not want to split your rules across multiple servers. In this case, you do not create server key mappings. Instead, you submit the request by specifying the rule group in the AsgnKey parameter for Assignment Manager. Even if there are no server key mappings, each Assignment Manager process loads all active rules. Assignment Manager determines at request time whether to execute all rules or only rules from a particular group, based on whether or not the assignment key is passed.
The following procedure summarizes the steps involved in running interactive assignment without using server key mappings.
To run interactive assignment without using server key mappings
  • Use the SetAsgnKey method to set the AsgnKey argument to the row ID of the rule group that you want to use.
