Running Mobile Assignment
Use mobile assignment to reassign people based on changes uploaded by Mobile Web Clients. Siebel Assignment Manager assigns objects after a Mobile Web Client synchronizes with the Siebel Server and uploads assignment requests or any changes to objects and assignment rules. Depending on the configuration of Generate Triggers, the Workflow Monitor detects these changes and activates Assignment Manager to dynamically reassign affected objects.
Note: If a Mobile Web Client sends an assignment request to the Siebel
Server while running mobile assignment, then the request is sent as
an asynchronous request. Because of this, the request does not override
the Keep Manual Assign property.
To run mobile assignment
Be sure that you have run the Generate Triggers server component.
For instructions, see Generating Triggers for Dynamic Assignment Using the GUI.
Start the Workflow Monitor Agent.
For instructions, see Starting Workflow Monitor Agent for Dynamic Assignment Using the Server Manager Command-Line Interface.
Note: If you are running interactive assignment, then make sure that the Server Request Broker server component is running. For instructions on checking the status of a server component, see Siebel System Administration Guide.
