Enabling Siebel to Oracle Fusion Knowledge Management Integration
Administrators need to set System Preference “Enable KM Service Integration” to Y for this feature to be used. Default value of this system preference will be N.
System Preference can be set by navigating to Sitemap > Administration – Application > System Preferences.
Post this Siebel Servers need to be restarted to take effect.
