Process of Setting Up Property Clusters
A cluster is a collection of individual properties that are grouped together for sales or revenue purposes. Properties can also be clustered if they are in close proximity to each other. Clustering can help with the sharing of assets between properties. A property can be associated with multiple clusters, depending on the purpose of each cluster.
Before completing this procedure, you must create property records to be included in the cluster, as described in Adding Property Records.
To set up property clusters, perform the following tasks:
This process is a step in Roadmap for Setting Up Hospitality Properties.
