Scale Unit Major
This user property is used to adjust the scaling factor on the major axis. You use this user property to define the scale unit of the major axis for different time scales in the Function Space Diary.
Property Description/Value
Value
1;0.25;2;1;4;0.5;8;4;16;7;32;1;64;1
Parent Object Type
TNT SHM Gantt AX Date Time Interval PopUp VBC
TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC
TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC
Usage
Determines the scale unit of the major axis for different time scales in the Function Space Diary. The value is a set of name-value pairs. The first part of the delimiter represents the time scale, and the second part represents the unit scale of the major axis.
