Scale Unit Minor
This user property is used to adjust the scaling factor on the minor axis. You use this user property to define the scale unit of the minor axis for different time scales in the Function Space Diary.
Property | Description/Value |
Parent Object Type |
TNT SHM Gantt AX Date Time Interval PopUp VBC Value: 1;1;2;1;4;.75;8;1;16;2;32;1;64;1;128;1;256;1 |
TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC Value: 1;1.5;2;1;4;1;8;4;16;7;32;1 |
TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC Value: 1;1.5;2;1;4;1;8;4;16;7;32;1 |
Usage |
Determines the scale unit of the minor axis for different time scales in the Function Space Diary. The value is a set of name-value pairs. The first part of the delimiter represents the time scale, and the second part represents the unit scale of the minor axis. |
