Segments Per Page Major
This user property is used to specify the number of segments per page to be displayed on the major axis, for each time scale. Use this user property to define the segments per page of the major axis for different time scales in the Function Space Diary.
Property Description/Value
Parent Object Type
TNT SHM Gantt AX Date Time Interval PopUp VBC
Value: 1;1;2;1;4;1;8;1;16;1;32;2;64;30;128;8;256;8
Parent Object Type
TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC
Value: 1;1;2;1;4;1;8;1;16;1;32;1
Parent Object Type
TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC
Usage
Determines the segments per page of the major axis for different time scales in the Function Space Diary. The value is a set of name-value pairs. The first part of the delimiter represents the time scale, and the second part represents the segments per page for the major axis.
