Creating Point Blocks for a Loyalty Promotion
If you selected Limited in the Point Limit Type field of the Promotion record, then you must associate a point block with the promotion, and this point block is used to give points for this promotion.
A subpoint block is created and associated with the promotion. The subpoint block takes a specified number of points from a point block that has been created and activated in the Program Administration screen, Point Blocks field.
For more information about fields in the Point Block record, see Creating Point Blocks for Loyalty Programs.
Note: Before doing this procedure, you must select Limited in the Point Limit Type field of the Promotion record. Otherwise, this view is read only.
To create a point block for a loyalty promotion
  1. Navigate to the Loyalty Promotions Administration screen.
  2. In the Promotions list, select the promotion that you want to create a point block for and click the hyperlink in its Promotion Number (#) field.
  3. If the promotion form’s Active check box is selected, then click Modify.
  4. Click the Point Blocks view tab.
  5. Add a new record to the Point Blocks list, and complete the necessary fields. Some fields are described in the following table.
    Field Description
    Name
    Enter the name for the subpoint-block.
    Parent Point Block
    Choose the parent point block.
    The pick applet shows active point blocks associated with the same partner as the promotion is hosted by.
    Total Points
    Enter how many points from the parent point block are available for use with this promotion.
    Status
    Select Approved to approve this point block.
