| Attach Method for an Application | Allows an external application to reconnect
to an existing Siebel session. | Dim application as SiebelDataControl
 Dim status as Boolean
 status
= application.Attach(sessionID As String)
| CurrencyCode Method for an Application | Returns the currency code that is associated
with the division of the user position. | Dim application as SiebelDataControl
 Dim sCur as String
 sCur = Application.CurrencyCode
| Detach Method for an Application | Returns a string that contains the Siebel
session ID. | Dim application as SiebelDataControl
 Dim sessionId as String
 sessionId
= application.Detach()
| EnableExceptions Method for an Application | Enables or disables native Component Object
Model (COM) error handling. | Dim application as SiebelDataControl
 Dim bEnable as Boolean
 bEnable
= trueapplication.EnableExceptions(bEnable)
| GetBusObject Method for an Application | Creates a new instance of a business object. | Dim application as SiebelDataControl
 Dim busObject as SiebelBusObject
 set busObject = application.GetBusObject(busobjName as String)
| GetLastErrCode Method for an Application | Returns the error code for the error that Siebel CRM logged most recently. | Dim application as SiebelDataControl
 Dim iErr as Integer
 iErr =
application.GetLastErrCode
| GetLastErrText Method for an Application | Returns the text message for the error that Siebel CRM logged most recently. | Dim application as SiebelDataControl
 Dim sText as String
 sText =
application.GetLastErrText
| GetProfileAttr Method for an Application | Returns the name of an attribute in a user
profile. | Dim application as SiebelDataControl
 Dim sText as String
 sText =
application.GetProfileAttr(profileAttributeName as string)
| GetService Method for an Application | Locates a business service. If this business
service is not already running, then Siebel CRM starts it. | Dim application as SiebelDataControl
 Dim service as SiebelService
 set service = application.GetService(serviceName as String)
| GetSharedGlobal Method for an Application | Returns the shared global variables. | Dim application as SiebelDataControl
 Dim sText as string
 sText =
application.GetSharedGlobal(globalVariableName as string)
| InvokeMethod Method for an Application | Calls a method. | Dim application as SiebelDataControl
 Dim sReturn as String
 sReturn
= application.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
| Login Method for an Application | Allows an external application to log in
to the COM Data Server, COM Data Control, or Siebel Java Data Bean,
and to access Siebel objects.  | Dim application as SiebelDataControl
 Dim sErr as String
 sErr = application.Login(connectString as String, userName as
String, password as String)
| LoginId Method for an Application | Returns the login ID of the user who started
the Siebel application. | Dim application as SiebelDataControl
 Dim sID as String
 sID = application.LoginId
| LoginName Method for an Application | Returns the login name of the user who started
 Dim sUser as String
 sUser =
application.LoginName
| Logoff Method for an Application | Disconnects the Siebel client from the Siebel
Server. | Dim SiebApp as SiebelDataControl
 Dim boolVal as Boolean
 boolVal
= siebApp.LogOff
| NewPropertySet Method for an Application | Creates a new property set. | Dim application as SiebelDataControl
 Dim PropSet as SiebelPropertySet
 PropSet = oApplication.NewPropertySet
| PositionId Method for an Application | Returns the position ID of the user position. | Dim application as SiebelDataControl
 Dim sRow as String
 sRow = application.PositionId
| PositionName Method for an Application | Returns the name of the current user position. | Dim application as SiebelDataControl
 Dim sPosition as String
 sPosition
= application.PositionName
| SetPositionId Method for an Application | Sets the active position to a Position ID. | Dim application as SiebelDataControl
 status
= application.SetPositionId(sPosId)
| SetPositionName Method for an Application | Sets the active position to a position name. | Dim application as SiebelDataControl
 status
= application.SetPositionName(sPosName)
| SetProfileAttr Method for an Application | Personalization uses this method to set a
value for an attribute in a user profile. | Dim application as SiebelDataControl
 application.SetProfileAttr(name as String, value as String)
| SetSharedGlobal Method for an Application | Sets a shared global variable. | Dim SiebApp as SiebelDataControl
 boolVal
= SiebApp.SetSharedGlobal(varName As String, value As String)
| Trace Method for an Application | Appends a message to the trace file. | Dim SiebApp as SiebelDataControl
 boolVal
= siebApp.TraceOn(msg As String)
| TraceOff Method for an Application | Turns off tracing. | Dim SiebApp as SiebelDataControl
 boolVal=siebApp.TraceOff
| TraceOn Method for an Application | Turns on tracing. | Dim SiebApp as SiebelDataControl
 boolVal
= siebApp.TraceOn(fileName As String, category As String, src As String)
