| ActivateField Method for a Business Component | Activates a field. | Dim busComp as SiebelBusComp
 BusComp.ActivateField(fieldName as String)
| ActivateMultipleFields Method for a Business Component | Activates multiple fields. | Dim busComp as SiebelBusComp
 busComp.ActivateMultipleFields(oPropSet as SiebelPropertySet)
| Associate Method for a Business Component | Creates a new many-to-many relationship for
the parent object through an association business component. | Dim busComp as SiebelBusComp
 busComp.Associate(whereIndicator as Integer)
| BusObject Method for a Business Component | Returns the name of the business object that
the business component references. | Dim busComp as SiebelBusComp
 Dim busObject as SiebelBusObject
 Set busObject = busComp.BusObject
| ClearToQuery Method for a Business Component | Clears the current query but does not clear
sort specifications on a business component. | Dim busComp as SiebelBusComp
 busComp.ClearToQuery
| DeactivateFields Method for a Business Component | Deactivates the fields that are currently
active from the SQL query statement of a business component.  | Dim busComp as SiebelBusComp
 busComp.DeactivateFields
| DeleteRecord Method for a Business Component | Removes the current record from a business
 busComp.DeleteRecord
| ExecuteQuery Method for a Business Component | Returns a set of business component records. | Dim buscomp as SiebelBusComp
 buscomp.ExecuteQuery(cursorMode As Integer) As Boolean
| ExecuteQuery2 Method for a Business Component | Returns a set of business component records.
Allows you to control the number of records Siebel CRM returns. | Dim buscomp as SiebelBusComp
 buscomp.ExecuteQuery2(cursorMode As Integer,ignoreMaxCursorSize
| FirstRecord Method for a Business Component | Moves the record pointer to the first record
in a business component, making that record the current record. | Dim busComp as SiebelBusComp
 Dim bIsRecord as Boolean
 bIsRecord
= busComp.FirstRecord
| GetFieldValue Method for a Business Component | Returns the value of a field from the current
record of a business component. | Dim busComp as SiebelBusComp
 Dim sValue as String
 sValue
= busComp.GetFieldValue(FieldName as String)
| GetFormattedFieldValue Method for a Business Component | Returns a field value that is in the same
format that the Siebel client uses. | Dim busComp as SiebelBusComp
 sValue
= busComp.GetFormattedFieldValue
| GetLastErrCode Method for a Business Component | Returns the error code for the error that Siebel CRM logged most recently. | Dim errCode As Integer
 Dim SiebApp as SiebelDataControl
 errCode=siebApp.GetLastErrCode
| GetLastErrText Method for an Application | Returns the text message for the error that Siebel CRM logged most recently. | Dim busComp as SiebelBusComp
 Dim sErr as String
 sErr = busComp.GetLastErrText
| GetMultipleFieldValues Method for a Business Component | Returns a value for each field specified
in a property set. | Dim busComp as SiebelBusComp
 busComp.GetMultipleFieldValues(oFieldNames as SiebelPropertySet,
oFieldValues as SiebelPropertySet)
| GetMVGBusComp Method for a Business Component | Returns the multivalue group business component
that is associated a business component field. | Dim busComp as SiebelBusComp
 Dim mVGBusComp as SiebelBusComp
 set mVGBusComp = busComp.GetMVGBusComp(FieldName as String)
| GetNamedSearch Method for a Business Component | Returns the name of a search specification. | Dim busComp as SiebelBusComp
 sValue
= busComp.GetNamedSearch(SearchName as String)
| GetPicklistBusComp Method for a Business Component | Returns the name of the pick business component
that is associated with a field in the current business component.  | Dim busComp as SiebelBusComp
 Dim pickBusComp as SiebelBusComp
 Set pickBusComp = busComp.GetPicklistBusComp(Field-Name as String)
| GetSearchExpr Method for a Business Component | Returns the current search expression that
is defined for a business component. | Dim busComp as SiebelBusComp
 Dim sExpr as String
 sExpr =
busComp.GetSearchExpr
| GetSearchSpec Method for a Business Component | Returns the search specification that is
 Dim sSpec as String
 sSpec =
busComp.GetSearchSpec(FieldName as String)
| GetUserProperty Method for a Business Component | Returns the value of a user property. | Dim buscomp as SiebelBusComp
 Dim retStr as String
 retStr
= buscomp.GetUserProperty(prop As String) As String
| GetViewMode Method for a Business Component | Returns the visibility mode for a business
 Dim iMode as Integer
 iMode
= busComp.GetViewMode
| InvokeMethod Method for a Business Component | Calls a method. | Dim busComp as SiebelBusComp
 Dim sReturn as String
 sReturn
= busComp.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
| LastRecord Method for a Business Component | Moves the record pointer to the last record
in a business component. | Dim busComp as SiebelBusComp
 Dim bReturn as Boolean
 bReturn
= busComp.LastRecord
| Name Method for a Business Component | Returns the name of a business component. | Dim busComp as SiebelBusComp
 Dim sName as String
 sName =
busComp.Name
| NewRecord Method for a Business Component | Adds a new record to a business component. | Dim busComp as SiebelBusComp
 busComp.NewRecord(whereIndicator as Integer)
| NextRecord Method for a Business Component | Moves the record pointer to the next record
 bReturn
= busComp.NextRecord
| ParentBusComp Method for a Business Component | Returns the name of a parent business component. | Dim busComp as SiebelBusComp
 Dim parentBusComp as SiebelBusComp
 Set parentBusComp = busComp.ParentBusComp
| Pick Method for a Business Component | Places the currently chosen record in a pick
business component into the appropriate fields of the parent business
 busComp.Pick
| PreviousRecord Method for a Business Component | Moves the record pointer to the previous
record in a business component, making that record the current record. | Dim busComp as SiebelBusComp
 bReturn
= busComp.PreviousRecord
| RefineQuery Method for a Business Component | Refines a query. | Dim busComp as SiebelBusComp
 busComp.RefineQuery
| SetFieldValue Method for a Business Component | Sets a new value in a field in the current
 busComp.SetFieldValue(FieldName as String, FieldValue as String)
| SetFormattedFieldValue Method for a Business Component | Sets a new value in a field in the current
record of a business component. It accepts the field value in the
current local format.  | Dim busComp as SiebelBusComp
 busComp.SetFormattedFieldValue(FieldName as String, FieldValue as String)
| SetMultipleFieldValues Method for a Business Component | Sets new values in the fields of the current
 busComp.SetMultipleFieldValues(oPropSet as SiebelPropertySet)
| SetNamedSearch Method for a Business Component | Sets a named search specification on a business
 busComp.SetNameSearch(searchName as String, searchSpec as String)
| SetSearchExpr Method for a Business Component | Sets a search expression for a business component. | Dim busComp as SiebelBusComp
 busComp.SetSearchExpr(searchSpec as String)
| SetSearchSpec Method for a Business Component | Sets the search specification for a business
 busComp.SetSearchSpec(FieldName as String, searchSpec as String)
| SetSortSpec Method for a Business Component | Sets the sort specification for a business
 busComp.SetSortSpec(sortSpec as
String)
| SetUserProperty Method for a Business Component | Sets the value of a named user property. | Dim buscomp as SiebelBusComp
 buscomp.SetUserProperty(property-Name as String, newValue as String)
| SetViewMode Method for a Business Component | Sets the visibility type for a business component. | Dim buscomp as SiebelBusComp
 Dim boolVal as Boolean
 boolVal
= buscomp.SetViewMode(mode As Integer)
| UndoRecord Method for a Business Component | Reverses any unsaved modifications made to
the record. | Dim busComp as SiebelBusComp
 busComp.UndoRecord
| WriteRecord Method for a Business Component | Saves to the Siebel database any modifications
made to the current record. | Dim busComp as SiebelBusComp
 busComp.WriteRecord
