Associating a Preventive Maintenance Plan with Vehicles
When you associate the preventive maintenance plan with a product, use this procedure to associate it to a specific vehicle or vehicles. After a preventive maintenance plan is associated with a vehicle, you can run the preventive maintenance engine to create preventive maintenance actions, activities, and service requests for the vehicle.
This task is a step in Process of Setting Up Preventive Maintenance.
To associate a preventive maintenance plan with a vehicle or vehicles
Navigate to the Preventive Maintenance screen, then the Preventive Maintenance List view.
Select a preventive maintenance plan record.
Click the Products view tab.
Select a product record.
Scroll down to the Assets list, add, edit, or delete records.
Note: This procedure can also be done using the Preventive Maintenance view of the Vehicles screen.
