Setting a Trigger for a Preventive Maintenance Plan
After a preventive maintenance plan has been set up and the appropriate service request templates and activity templates have been defined, you can set the trigger for a preventive maintenance plan, which defines the type of plan and how the service interval is determined in Siebel Automotive. This procedure is based on a mileage trigger for maintenance.
This task is a step in Process of Setting Up Preventive Maintenance.
To set up a trigger for a preventive maintenance plan
  1. Navigate to the Preventive Maintenance screen, then the Preventive Maintenance List view.
  2. Select a preventive maintenance plan record.
  3. Click the Triggers view tab, and take the following action:
    • Time Interval list.Add, Edit, or Delete records.
    • Usage list. Add, Edit, or Delete records.
    • Month-Day list. Add, Edit, or Delete records.
    • Threshold list. Add, Edit, or Delete records.
    • Event list. Add, Edit, or Delete records.
    Note: Preventive maintenance plans can have any number of triggers of any type (Time Interval, Usage, Threshold, and Event).
Related Topics
Associating a Preventive Maintenance Plan with a Product
Associating a Preventive Maintenance Plan with Vehicles
