Benefits of Using an Error Workflow Process
A universal exception handler is an error Workflow Process that Siebel CRM can use to handle an error that occurs across multiple steps in a Workflow Process or across multiple Workflow Processes. You can use it to reduce clutter in a Workflow Process diagram. You can reuse a single error Workflow Process that handles the same error for multiple calling Workflow Process.
