Defining Properties and Arguments for Workflow Process Steps
This task is a step in Defining a Workflow Process That Creates an Activity for a Sales Representative.
In this topic, you define properties and arguments for Workflow Process steps.
To define properties and arguments for Workflow Process steps
Click the Insert Activity to Follow Up step and in the Properties pane, set the properties as shown in following table.
Property
Value
Business Component
Action
Operation
Insert
Select the Insert Activity to Follow Up step in the Process Designer and in the Multi Value Property Window (MVPW) pane, add an input argument with the values shown in the following table.
You must first define the Field Name first, and then the Value.
Field Name
Type
Value
Description
Literal
This is a large opportunity. Please call the customer ASAP.
For more information, see Arguments You Can Define for a Process Property.
Add a second property with the values shown in the following table.
Field Name
Type
Value
Type
Expression
To Do
