Entering and Reviewing Data for 3500A Reports
When you populate a regulatory report, many fields are copied from the product issue record. When you edit these fields in the regulatory report record, the edits are not copied back to the product issue record.
Note: The process described here is to enter data in the Manufacturer, Investigation, and Importer views of the Regulatory Reports screen. However, an alternate way is to enter the data in these views in the Product Issues screen before the regulatory report is populated. If you use the Product Issues screen, you have copies of the data in both the product issue record and in the regulatory report record.
This task is a step in Process of Regulatory Reporting.
To review and enter data for the 3500A report
  1. Navigate to Regulatory Reports screen, then the Regulatory Report List view.
  2. In the Regulatory Report List, drill down on a 3500A regulatory report record.
  3. Review and if necessary modify the information in the More Info and Patient views.
  4. If you are a manufacturer:
    1. Make sure that the Facility Type field in the Importer view is blank. By default, this field is set to blank.
    2. Complete the fields in the Manufacturer view.
      These fields populate section G of the 3500A form. Some fields are described in the following table. Note that the letter and number combination in the last column indicates how this field maps to the 3500A form.
      Field Comments Mapping to 3500A Form
      (A)NDA #
      The abbreviated new drug application or the new drug application number.
      This field is automatically populated if there is an (A)NDA number associated with the protocol site.
      G5
      10-day
      Select the check box to indicate the report is a 10-day report.
      G7
      15-day
      For reports of serious and unexpected adverse events.
      G7
      5-day
      For events requiring remedial action to prevent unreasonable risk to public health, or where written notice is required.
      G7
      Address
      Manufacturer contact office address - Street.
      G1
      AE Terms
      List of adverse event terms that most accurately characterize the adverse event described in Event Detail section.
      G8
      City
      Manufacturer contact office address - City.
      G1
      Consumer
      Report Source is the consumer or treating health care provider.
      G3
      Contact Name
      Manufacturer contact’s last name.
      G1
      Contact Office
      Manufacturer’s contact office.
      G1
      Country
      Manufacturer contact office address - Country.
      G1
      Distributor
      Check this if report was received from the distributor (importer) of the suspect product.
      G3
      First Name
      Manufacturer contact’s first name.
      G1
      Follow-up
      Check if the report is a follow-up to a previously submitted report.
      G7
      Follow-Up #
      Follow-up sequence number.
      G7
      Foreign
      Report Source is a foreign source (for example, foreign medical facility, affiliate, or government).
      G3
      IND #
      The investigational new drug (IND) application number.
      This field is automatically populated if there is an IND number associated with the protocol site.
      G5
      Initial
      Check if the report is the first submission of a manufacturer report (30 day report for device).
      G7
      Literature
      Report Source is the scientific literature or an unpublished manuscript.
      G3
      Mfg Report #
      Regulatory report number.
      G9
      OTC Product
      Check if the suspect medication can be purchased over-the-counter (without a prescription).
      G5
      Other
      Report Source is any source not covered by the previous categories.
      G3
      Periodic
      For reports of serious labeled and non-serious (labeled and unlabeled) adverse events.
      G7
      Phone #
      Manufacturer contact’s work phone number.
      G2
      PI Received
      The date when a company representative became aware of the event.
      G4
      Postal Code
      Manufacturer contact office address - Postal Code.
      G1
      Pre-1938
      Check the box if the suspect medication was marketed prior to 1938 and does not have an NDA #.
      G5
      Products
      Product(s) involved in the event.
      Professional
      Report Source is a physician, pharmacist, nurse, and so on.
      G3
      Protocol #
      Protocol number identifies the clinical trial at a site. If regulatory report is an IND safety report, enter the protocol number.
      G6
      Received Report #
      Report number for the MedWatch form received from a Importer or a User Facility.
      MedWatch Header
      Representative
      Check this if a company representative reported the event based on information from a health professional.
      G3
      State
      Manufacturer contact office address - State.
      G1
      Study
      Report Source is a postmarketing, clinical trial, surveillance, or other study.
      G3
      User Facility
      Check this if the manufacturer received the report from the MDR contact in a user facility as identified in section F.
      G3
  5. If you are a device manufacturer, complete the fields in the Investigation view.
    These fields populate section H of the 3500A form. Some fields are described in the following table. Note that the letter and number combination in the last column indicates how this field maps to the 3500A form.
    Evaluation
    If an evaluation was conducted, note summary here and choose Evaluation Summary Attached in Evaluated by Mfg Field.
    H3
    Death
    Check only if the death was an outcome of the adverse event.
    H1
    Correction
    Do not check when creating an initial report.
    Follow-up with changes to previously submitted information.
    H2
    Serious Injury
    Event is life-threatening, results in permanent impairment, requires intervention to prevent permanent impairment.
    H1
    Additional Information
    Information concerning the event that was not provided in the initial report.
    H2
    Malfunction
    Device malfunctions.
    H1
    Response to FDA Request
    Additional information requested by FDA concerning the device/event.
    H2
    Other
    Event not covered by death, serious injury, or malfunction. This type of category should be rarely used.
    H1
    Device Evaluation
    Evaluation/analysis of device.
    H2
    Mfg Narrative
    Any additional information, evaluation, or clarification of data presented in previous sections.
    H10
    Recall
    Remedial Action - Recall.
    H7
    Method Codes
    Method codes capture two items — the source of the device that was evaluated and the type of evaluation performed.
    Do not enter more than four codes.
    H6
    Repair
    Remedial Action - Repair.
    H7
    Result Codes
    Describes the results of evaluation and analyses of the reported device problem(s).
    H6
    Replace
    Remedial Action - Replace.
    H7
    Conclusion Codes
    Describes the evaluation conclusions.
    H6
    Relabeling
    Remedial Action - Relabeling.
    H7
    Evaluated by Mfg
    If you do not check this box, then you should complete the Non-Evaluation Codes field.
    Identify if the device was evaluated.
    H3
    Notification
    Remedial Action - Notification.
    H7
    If an evaluation of a returned medical device was NOT conducted, provide the appropriate code.
    H3
    Corrected Data
    Additional, corrected, or missing information, identifying each data item by the applicable section and block number.
    H11
    Inspection
    Remedial Action - Inspection.
    H7
    Usage of Device
    Indicates whether the use of the suspect medical device was the initial use, reuse, or unknown.
    H8
    Patient Monitoring
    Remedial Action - Patient monitoring.
    H7
    Mfg Date
    Month and year of manufacture of the suspect medical device.
    This field can be based on asset number (asset manufacture date) or lot number (effective start date).
    H4
    Modification
    Remedial Action - Modification.
    H7
    Labeled Single Use
    Indicates whether the device was labeled for single use.
    H5
    Other
    Remedial Action - Other - Specify the type of action in this field.
    H7
    Correction #
    If action reported to FDA under 21 USC 360i(f), list correction or removal reporting number.
    H9
  6. If you are a user facility or importer, complete the fields in the Importer view.
    These fields populate section F of the form. Some fields are described in the following table. Note that the letter and number combination in the last column indicates how this field maps to the 3500A form.
    Facility Type
    Indicate whether the report is from a user facility, importer, or others.
    F1
    Importer
    Name of the distributor or importer.
    F3
    Contact Name
    Last name of the distributor’s or importer’s representative to contact regarding the event.
    F4
    Device Age
    The approximate age of the device.
    F9
    Report #
    Regulatory report # for this report, which is being submitted by an importer.
    This number is auto-populated when the report is generated.
    F2
    Address
    Distributor’s or Importer’s address - Street Address line #1.
    This field is auto-populated based on the distributor’s or importer’s name.
    F3
    First Name
    First name of the distributor’s or importer’s representative to contact regarding the event.
    F4
    Age UoM
    Unit of measurement for device age.
    F9
    Report Type
    Indicates if the report to the regulatory agency will be an initial or follow-up report.
    F7
    City
    Distributor’s or importer’s address - City.
    F3
    Phone #
    Contact’s work phone number.
    F5
    Patient Codes
    Patient codes describe what happened to the patient as a result of the event.
    Do not enter more than three codes.
    F10
    Follow-up #
    Sequence number of the follow-up report.
    F7
    Postal Code
    Distributor’s or importer’s address - Postal Code.
    F3
    Reported FDA
    Indicates if the distributor or importer has already sent a report to the regulatory agency.
    F11
    Device Codes
    Device codes describe device failures or problems encountered during the event.
    F10
    Reported Mfg
    Indicates if the distributor or importer has sent a report to the manufacturer.
    F13
    State
    Distributor’s or importer’s address - State.
    F3
    FDA Report Date
    Date the report was sent to the regulator agency.
    F11
    Event Location
    Location of the actual occurrence of the event.
    F12
    Mfg Report Date
    Date the report was sent to the manufacturer.
    F13
    Country
    Distributor’s or importer’s address - Country.
    F3
    PI Received
    F6
