Entering and Reviewing Data for MDV Reports
When you populate the regulatory report, many fields are copied from the product issue record. When you edit these fields in the regulatory report record, the edits are not copied back to the product issue record.
This task is a step in Process of Regulatory Reporting.
To review and enter data for an MDV Initial report
Navigate to Regulatory Reports screen, then the Regulatory Report List view.
In the Regulatory Report List, drill down on an MDV regulatory report record.
Review and if necessary modify the information in the More Info and Patient views.
Click the MDV tab.
On the MDV form, complete the necessary fields.
Some fields are described in the following table.
Field Comments MDV Report #
MDV Report number.
This number is auto-populated when the report is generated.
Authorities
The name of the regulatory agencies to send the report to.
Affiliate Acct
The affiliate account representing the company.
PI Received
The date when the company became aware of the event.
Determination
The type of the reportable event for MDV reporting.
Patient Codes
Patient codes describe what happened to the patient as a result of the event.
Device Codes
Device codes describe device failures or problems encountered during the event.
Usage of Device
Indicates whether the use of the suspect medical device was the initial use, reuse, or unknown.
Follow-up Date
Date field to indicate the approximate follow-up or final report date.
Approval Org
The approval body for the device.
Approval #
The approval number for the device.
Evaluation
If the evaluation was conducted, note summary here and choose Evaluation Summary Attached in Evaluated by Mfg field.
Mfg Narrative
Any additional information, evaluation, or clarification of data presented in previous sections.
