Using System Preferences to Set Up Variable Maps for Pricing Adjustments
Use the following procedure to set up variable maps for pricing adjustments by modifying system preferences
To set up variable maps for pricing adjustments using the System Preferences view
  1. Navigate to the Administration - Application screen, then System Preferences view.
  2. In the System Preferences list, query for: PSP Pricing Var Map*
    Three records appear, as detailed in the table in Using Variable Maps in Attribute Adjustments.
  3. Set the appropriate variable map names in the System Preference Value field.
  4. Restart the server.
    New attribute adjustments created after the server is restarted use the new variable maps declared in system preferences.
