Using the Variable Maps View to Set Up Variable Maps for Pricing Adjustments
Use the following procedure to set up variable maps for pricing adjustments by overwriting the variable maps in the Variable Map view.
To set up variable maps for pricing adjustments using the Variable Maps view
Navigate to the Administration - Pricing screen , Attribute Adjustments, then Variable Map view.
Modify variable maps by selecting different variable maps in the picklists.
The first approach is a global level change, and any new attribute adjustment table created after the server is restarted uses the new variable maps. The second approach is a local level change, and only the attribute adjustment that is modified uses the new variable maps.
