Macro Expansion with Phone Numbers
Macro expansion provides many options for retrieving and manipulating phone number data for use with communications events or commands. This topic applies to event and command parameters only.
The macro @Phone is often used to retrieve a phone number; for a detailed description of this macro and its encoded logic, see Macros for Parameter Values. Alternatively, you can explicitly specify the name of a field from which to extract phone number data.
For information about phone number formatting, including formatting for international numbers, see Siebel Applications Administration Guide.
You can use the following special macro-expansion features when retrieving phone number data:
A keyword to specify how to apply dialing filters to the field value. For more information about the keywords, see Keywords to Specify Dialing-Filter Behavior.
A keyword to indicate the part of the phone number that you want to extract. For more information about the keywords, see Keywords to Extract Part of a Phone Number.
A specific range of numerals to extract from the field value. For more information about the ranges, see Numeric Ranges to Extract.
