@Phone Macro Example
The example command and associated command data shown in the following table and second table in this topic use the @Phone macro, which you can use to dial any phone field on any business component.
Parameter Name | Parameter Value |
Description |
Make Call to "{@Phone}" |
DeviceCommand |
MakeCall |
Hidden |
True |
The following table shows a command data definition for this command definition.
AttachContext |
True |
Param.CallNotifyText |
Call from {@UserName}... |
Param.PhoneNumber |
{@Phone:PhoneTypeLookup} |
RequiredField.@Phone |
