Enabling Component Groups for Siebel Territory Management
You must enable the component groups on the server that are used by Siebel Territory Management.
This task is a step in Process of Setting Up Siebel Territory Management.
To enable component groups
Navigate to the Administration – Server Configuration screen, Enterprises, and then Component Groups view.
In the Component Groups list and Components sublist, select the following components and click Enable:
Assignment Management group, Batch Assignment component.
Workflow Management group, Workflow Process Manager component.
Siebel RTI group, RTI Batch component.
