Verifying Enterprise Data for Siebel Territory Management
Siebel Territory Management uses data that has probably already been entered in your Siebel Business applications, such as accounts and contacts. You should verify that this data has been entered and is available for Siebel Territory Management.
This task is a step in Process of Setting Up Siebel Territory Management.
The following table summarizes the enterprise data used by Siebel Territory Management.
| Enterprise Data | Description | For More Information |
Account and Contact objects |
If you are going to be assigning accounts and contacts to territories, make sure that the data for these objects is accurate and complete. |
Siebel Applications Administration Guide |
Asset objects |
If you are going to be assigning assets to territories, make sure that the data for these objects is accurate and complete. |
Siebel Field Service Guide |
Geo zone objects (or bricks) |
You can define your territories by geo zone instead of by postal code. For example, if your syndicated data is provided for geo zone, then define your territories by geo zone. |
Siebel Life Sciences Guide |
Opportunity objects |
If you align territories by opportunity, then you must create the opportunities and assign them to sales representatives. |
