Creating a Migration Plan
This procedure describes how to use Siebel Migration to create a migration plan for a migration. The procedure involves selecting connections, including Source and Target environments, and resources that you want to migrate as part of the migration plan. In Siebel Migration, you can select Database Utilities, ADM Projects or File Prepare and Deploy services. When you run a migration plan, Siebel Migration exports the migration data from the Source environment and imports it into the Target environment.
This task is a step in Process of Using Siebel Migration to Migrate Data.
To create a migration plan
  1. In the Siebel Migration Application, click Migration Plans in the navigation menu in the side panel to go to the Migrations Plans screen.
  2. Click New Migration.
  3. Enter the Name of the Migration Plan and a Description.
  4. Select and move the Source Connection & Target Connection onto the Flow Chart.
    An intersection of Migration Resources (between Source & Target) for Database Utilities and only from Source for ADM Projects will be displayed.
  5. Select the Migration Resource that will be executed as part of the migration plan.
