Types of Watermarks
There are several types of watermarks in a generated watermark file, including the following:
Source Integration Workspace and Version for Workspace-enabled objects.
Last Updated Date for objects that are not Workspace-enabled (such as schema changes).
Checksums for files when using the File Prepare and Deploy service.
The target environment's binary version – this allows for proper migration when the target environment is on a lower Siebel CRM monthly update version.
