Scenario for Using a Watermark
Consider performing a full migration from a source DR to a test RR environment. The Integration Workspace in the source might be "int_May_2022" and on version 19. When a full migration is executed, the target RR environment will have a MAIN Workspace version of "0" and the information that it came from (int_May_2022) will also be stored.
At some point in the future, after a few features have been delivered and some bugs fixed, int_May_2022 might be on version 27 and you want to migrate only the changes to the test RR environment. To do this:
You need to determine what was sent the last time that migration occurred. You do this by querying the target environment for the watermark.
The RR environment responds (in this case) that it was last updated from the int_May_2022\19 Integration Workspace, and the migration execution on the DR environment packages up the correct contents accordingly.
