Creating an ADM Data Map
This topic provides procedures for creating an ADM Data Map.
This task is a step in Process of Preparing Siebel Application Data for Migration.
To create an ADM data map
Navigate to the Site Map, Administration - Integration, and then Data Map Editor.
In the Data Map Editor applet, create a new record.
Enter a Name for the data map.
Choose the Integration Object that is used in the Data Type for both the Source Object Name and the Target Object Name.
Click Auto-Map to populate the Integration Component Map and Integration Field Map fields.
In the Integration Component Map applet, select the Integration Component to transform the data.
In the Integration Field Map applet, select the Field to transform the data.
In the Source Expression column, enter the expression to transform the data. For more information about supported expressions, see Siebel Application Deployment Manager Guide.
Click Save.
