Process of Transforming Data with Siebel Application Deployment Manager
Application Deployment Manager (ADM) is a Siebel tool that you can use to deploy data from the source environment to the target environments. For more information about Application Deployment Manager, see Siebel Application Deployment Manager Guide.
For your data migration, you can use ADM to:
Create ADM Projects that can be migrated by Siebel Migration. For more information about creating ADM projects, see Application Deployment Manager Guide.
When you create your ADM Project, you can configure the Sequence Number. The Sequence Number is populated in the Project Items. ADM migrates the Project Items in the sequence order according to the value of the Sequence Number parameter. If the sequence number is not provided, ADM will follow the default behavior.
Create an ADM Data Map to transform data before importing into the target environment. For more information about creating ADM maps, see Creating an ADM Data Map.
Associate your data map to your project item. For more information about associating data maps to ADM projects, see Associating a Data Map to a Project Item.
