Creating the Schema on the Target Database
Perform the following procedure to create the Siebel CRM schema for the current release on the target database.
To create the Siebel CRM schema on the target database
On the Target Database Non-Additive Processes menu, select option 2: Create Schema, and press Enter.
The following message appears:
Before proceeding, make sure ALL “UNLOAD jobs completed. Re-enter option 2 to continue.
Reselect option 2: Create Schema, and press Enter.
Run the job using the JCL in data set
DSNHLQ.SIEBEL.INSTALL.JCL(SCHEMAT)
.Verify that each job ran successfully with a return code of 0 or 4. For information, see Verifying JCL Upgrade Jobs
After submitting the job, enter cancel on the command line or press PF3 to save changes.
