Deleting Unload Data Sets
When your database upgrade is completed, you no longer require the Unload data sets. Perform the following procedure to generate a list of the Unload data sets and then delete them.
Note: Before performing this procedure, you must have the
*.siebel.exec
library allocated.To delete unload data sets
Log on to the z/OS host.
Enter the following command and press Enter:
TSO SBLDELDS
A list of the unload data sets to be deleted is generated.
Navigate to the
*.siebel.install.jcl
library.Submit the JCL in the data set
&DSNHLQ.SIEBEL.INSTALL.JCL(DELULDS)
to delete the Unload data sets.Verify that the job ran successfully with a return code of 0. For information, see Verifying JCL Upgrade Jobs.
