Removing the Staging Database
After you have successfully completed your database upgrade, you must remove the staging database objects before you can reuse the same database prefix and tableowner name.
To remove the staging database
  1. Log on to the z/OS host.
  2. Submit the JCL in the &DSNHLQ.SIEBEL.INSTALL.JCL(STGDROPJ) data set.
    The staging database objects are removed.
  3. Press PF3 to complete the process.
